이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
Use the T5 Torx screwdriver to remove the four screws in each corner.
Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
Dislocate the small piece with the wires connected using a nylon spudger.
Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
After the battery has been removed, there are two screws that also need to be removed
There are two gold strips that you must disconnect from the motherboard, They simply pop right off.
Remove the circular piece from the motherboard.
Proceed to pry off the motherboard. Go around all edges with the plastic opening tool and it should come off with ease.
Next, the motherboard should still be connected by a wire that leads to the bottom portion of the phone.
To remove the black plastic piece there is one screw that needs to be removed then you can pry it off with the plastic opening tool.
To fully remove the motherboard the last step is to disconnect the wire that was previously mentioned.
Remove the motherboard.
After the phone is gutted, all that is left is to pry the actual screen off from the backing and prepare for replacement.
다른 2명이 해당 안내서를 완성하였습니다.
