소개
Is your HTC Desire 610 not holding a charge? Instead of taking it to your phone provider, follow these steps and you can replace that old battery in no time! It's as simple as: take off the back, unscrew the circuit cover, pry out the old battery, and put in a new one. Ta-dah!
필요한 것
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
@simon and anybody, Another suggestion is to control the connect cable screen which passes under the battery and plugs upside down under the motherboard because it is frequent that it disconnects when we remove the old battery and the smartphone no longer restarts Next.
Thank you very much to the author of this tutorial which I serve me for a friend in January 2024
