주요 콘텐츠로 건너뛰기
HTC Desire 610 Charging Port Replacement
필요한 것
  1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: 1 단계, 이미지 1/3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: 1 단계, 이미지 2/3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: 1 단계, 이미지 3/3
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Charging Port Replacement: 3 단계, 이미지 1/1
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Charging Port Replacement: 5 단계, 이미지 1/1
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Charging Port Replacement, Charging Port: 6 단계, 이미지 1/1
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  7. HTC Desire 610 Charging Port Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, disconnect the antenna wire.
  8. HTC Desire 610 Charging Port Replacement: 8 단계, 이미지 1/3 HTC Desire 610 Charging Port Replacement: 8 단계, 이미지 2/3 HTC Desire 610 Charging Port Replacement: 8 단계, 이미지 3/3
    • Peel back the gray adhesive strip using the precision tweezers.
  9. HTC Desire 610 Charging Port Replacement: 9 단계, 이미지 1/1
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  10. HTC Desire 610 Charging Port Replacement: 10 단계, 이미지 1/3 HTC Desire 610 Charging Port Replacement: 10 단계, 이미지 2/3 HTC Desire 610 Charging Port Replacement: 10 단계, 이미지 3/3
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  11. HTC Desire 610 Charging Port Replacement: 11 단계, 이미지 1/3 HTC Desire 610 Charging Port Replacement: 11 단계, 이미지 2/3 HTC Desire 610 Charging Port Replacement: 11 단계, 이미지 3/3
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kaycee Hammond
회원 가입일: 02/11/17
273 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G1, Wilson Spring 2017 IUPUI, Team S1-G1, Wilson Spring 2017 회원
IUPUI-WILSON-S17S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 1,234
