소개
Use this guide to replace the charging port in the HTC Desire 626s.
The charging port is responsible for transmitting electricity to the phone’s battery. Dust, dirt, debris, and bad quality chargers can damage the charging port, resulting in an inability to charge the phone.
Before you replace the charging port, try to charge the phone using different chargers in order to confirm that the charging port is damaged.
필요한 것
Insert plastic opening tool in between the back cover and grey plastic.
Gently work your way around the phone while sliding the tool.
Gently pry on plastic cover as needed to release fasteners.
Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
By using the angled tweezers, you have to be careful when you try to remove the battery connection by start pulling the wires.
Using tweezers, peel back the plastic as shown in these two pictures.
You will need to pull it back as shown in picture 2 for future steps.
다른 2명이 해당 안내서를 완성하였습니다.
