주요 콘텐츠로 건너뛰기
HTC Desire 816 Camera Replacement
필요한 것
  1. HTC Desire 816 Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Camera Replacement: 2 단계, 이미지 1/1
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Camera Replacement: 3 단계, 이미지 1/1
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Camera Replacement: 4 단계, 이미지 1/1
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Camera Replacement: 5 단계, 이미지 1/1
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Camera Replacement: 6 단계, 이미지 1/1
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Camera Replacement: 7 단계, 이미지 1/1
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Camera Replacement, Back Facing Camera: 8 단계, 이미지 1/1
    • Take the T5 screwdriver head to take out these 4 screws
  9. HTC Desire 816 Camera Replacement: 9 단계, 이미지 1/1
    • Remove the black plastic casing with a plastic opening tool.
  10. HTC Desire 816 Camera Replacement: 10 단계, 이미지 1/1
    • Take the PH000 screwdriver head to take out the one screw that's holding down the green panel. (The screw is located on the left side of the panel)
  11. HTC Desire 816 Camera Replacement: 11 단계, 이미지 1/1
    • With your pair of tweezers carefully unplug the black and red wire in order to remove the motherboard
  12. HTC Desire 816 Camera Replacement: 12 단계, 이미지 1/1
    • Once you have removed the wire, you can carefully lift up the motherboard
  13. HTC Desire 816 Camera Replacement: 13 단계, 이미지 1/1
    • Peel off the yellow film that’s attaching the camera to the motherboard
  14. HTC Desire 816 Camera Replacement: 14 단계, 이미지 1/1
    • Slowly lift up the white connector so that the camera’s cable may properly be detached.
  15. HTC Desire 816 Camera Replacement: 15 단계, 이미지 1/1
    • Carefully peel off the adhesive so that the camera can be disconnected from the mother board
결론
다른 4명이 해당 안내서를 완성하였습니다.
Saleena Douangphachanh
회원 가입일: 03/05/16
612 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 16
전체 시간: 2,557
