주요 콘텐츠로 건너뛰기
HTC Desire 816 Speaker Replacement
필요한 것
  1. HTC Desire 816 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Speaker Replacement: 2 단계, 이미지 1/1
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Speaker Replacement: 3 단계, 이미지 1/1
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Speaker Replacement: 4 단계, 이미지 1/1
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Speaker Replacement: 5 단계, 이미지 1/1
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Speaker Replacement: 6 단계, 이미지 1/1
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Speaker Replacement: 7 단계, 이미지 1/1
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Speaker Replacement, Bottom Speakers: 8 단계, 이미지 1/1
    • Using the T5 screw driver, unscrew the following screws.
  9. HTC Desire 816 Speaker Replacement: 9 단계, 이미지 1/1
    • Using the T5 screw driver remove the remaining screw at the bottom right corner of the phone.
  10. HTC Desire 816 Speaker Replacement: 10 단계, 이미지 1/1
    • Lift and remove black plastic casing with a nylon spudger to access the motherboard and speaker.
  11. HTC Desire 816 Speaker Replacement: 11 단계, 이미지 1/1
    • Using the PH000 unscrew the following screws that are holding down the motherboard.
  12. HTC Desire 816 Speaker Replacement: 12 단계, 이미지 1/1
    • Using the PH000 screw driver, unscrew the remaining screw.
  13. HTC Desire 816 Speaker Replacement: 13 단계, 이미지 1/1
    • Gently disconnect the wire located on the right side of the device from the bottom motherboard .
  14. HTC Desire 816 Speaker Replacement: 14 단계, 이미지 1/1
    • Using a pair of tweezers, gently grab and lift the motherboard.
  15. HTC Desire 816 Speaker Replacement: 15 단계, 이미지 1/1
    • Using a pair of tweezers, gently grab and remove the speaker.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Saleena Douangphachanh
회원 가입일: 03/05/16
612 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G3
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Where do you acquire new speakers? Can you tell me if the speakers are as powerful as the ones in the M8
Peter Ford - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,017
