주요 콘텐츠로 건너뛰기
HTC Desire 816 Top Speaker Replacement
필요한 것
  1. HTC Desire 816 Top Speaker Replacement, Top Speaker: 1 단계, 이미지 1/1
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. HTC Desire 816 Top Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. HTC Desire 816 Top Speaker Replacement: 3 단계, 이미지 1/1
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. HTC Desire 816 Top Speaker Replacement: 4 단계, 이미지 1/1
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. HTC Desire 816 Top Speaker Replacement: 5 단계, 이미지 1/1
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. HTC Desire 816 Top Speaker Replacement: 6 단계, 이미지 1/1
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Edward Garcia
회원 가입일: 03/25/16
527 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 10
전체 시간: 1,276
