소개
This guide will outline how to remove the logic board assembly, including cables, from the HTC Desire V smartphone
필요한 것
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
Unplug the vibration motor shown from the white plug on the motherboard.
You will probably need tweezers to do this.
Remove the black information sticker if this is the first time opening the handset.
You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
For this you may wish to use a spudger or tweezers.
다른 한 분이 해당 안내서를 완성하였습니다.
