주요 콘텐츠로 건너뛰기
HTC Droid DNA Rear-Facing Camera Replacement
필요한 것
  1. HTC Droid DNA Rear-Facing Camera Replacement, Remove the SIM Card Tray: 1 단계, 이미지 1/1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 2 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 2 단계, 이미지 2/2
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 3 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 3 단계, 이미지 2/2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Rear-Facing Camera Replacement, Pull the Casing Apart: 4 단계, 이미지 1/1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Tape: 5 단계, 이미지 1/1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
  6. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 6 단계, 이미지 1/1
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  7. HTC Droid DNA Rear-Facing Camera Replacement: 7 단계, 이미지 1/1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Void Screw: 8 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  9. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screw Retaining Bracket: 9 단계, 이미지 1/1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Connector Screws: 10 단계, 이미지 1/1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 11 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 11 단계, 이미지 2/2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 12 단계, 이미지 1/1
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 13 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 13 단계, 이미지 2/2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 14 단계, 이미지 1/1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 15 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 15 단계, 이미지 2/2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 16 단계, 이미지 1/1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 17 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 17 단계, 이미지 2/2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 18 단계, 이미지 1/1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 19 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 19 단계, 이미지 2/2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Small Ribbon Connector: 20 단계, 이미지 1/1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Wire: 21 단계, 이미지 1/1
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Two Black Wires: 22 단계, 이미지 1/1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
  23. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screws: 23 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 24 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 24 단계, 이미지 2/2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  25. HTC Droid DNA Rear-Facing Camera Replacement, Remove Screws: 25 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
  26. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 26 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 26 단계, 이미지 2/2
    • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
    • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
  27. HTC Droid DNA Rear-Facing Camera Replacement, Remove Camera Board: 27 단계, 이미지 1/1
    • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
  28. HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 28 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 28 단계, 이미지 2/2
    • Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
  29. HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 29 단계, 이미지 1/2 HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 29 단계, 이미지 2/2
    • Use your tweezers to gently flip the white connector board into the upright position.
  30. HTC Droid DNA Rear-Facing Camera Replacement, Remove Rear-Facing Camera: 30 단계, 이미지 1/1
    • Use your tweezers to remove the rear-facing camera from the camera board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Adrian Williams
회원 가입일: 10/14/14
585 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G43
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,054
