주요 콘텐츠로 건너뛰기
HTC Droid Incredible 4G LTE Display Assembly Replacement
필요한 것
  1. HTC Droid Incredible 4G LTE Display Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
  2. HTC Droid Incredible 4G LTE Display Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the battery after taking off the cover.
  3. HTC Droid Incredible 4G LTE Display Assembly Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove eight 4mm and one 5mm Torx screws.
  4. HTC Droid Incredible 4G LTE Display Assembly Replacement: 4 단계, 이미지 1/2 HTC Droid Incredible 4G LTE Display Assembly Replacement: 4 단계, 이미지 2/2
    • Use a prying tool to pry off the midframe.
  5. HTC Droid Incredible 4G LTE Display Assembly Replacement, Micro USB Port: 5 단계, 이미지 1/1
    • Remove the 4mm Torx screw holding the charging port to the phone.
  6. HTC Droid Incredible 4G LTE Display Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the silver bracket holding the charging port in place.
  7. HTC Droid Incredible 4G LTE Display Assembly Replacement: 7 단계, 이미지 1/1
    • Use a prying tool to remove the charging port as shown.
  8. HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: 8 단계, 이미지 1/3 HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: 8 단계, 이미지 2/3 HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: 8 단계, 이미지 3/3
    • Pry off and remove the back cover
  9. HTC Droid Incredible 4G LTE Display Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the 4mm Torx screw.
  10. HTC Droid Incredible 4G LTE Display Assembly Replacement: 10 단계, 이미지 1/3 HTC Droid Incredible 4G LTE Display Assembly Replacement: 10 단계, 이미지 2/3 HTC Droid Incredible 4G LTE Display Assembly Replacement: 10 단계, 이미지 3/3
    • Remove tabs holding the motherboard to the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tevin
회원 가입일: 09/24/14
666 평판
안내서 4개 작성하였습니다
USF Tampa, Team 15-1, Remmell Fall 2014 USF Tampa, Team 15-1, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 1,039
