소개
Use this guide to replace or upgrade the battery in your Droid Incredible.
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
