주요 콘텐츠로 건너뛰기
HTC Droid Incredible MicroSD card Replacement
  1. HTC Droid Incredible MicroSD card Replacement, Battery: 1 단계, 이미지 1/3 HTC Droid Incredible MicroSD card Replacement, Battery: 1 단계, 이미지 2/3 HTC Droid Incredible MicroSD card Replacement, Battery: 1 단계, 이미지 3/3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible MicroSD card Replacement: 2 단계, 이미지 1/1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible MicroSD card Replacement: 3 단계, 이미지 1/3 HTC Droid Incredible MicroSD card Replacement: 3 단계, 이미지 2/3 HTC Droid Incredible MicroSD card Replacement: 3 단계, 이미지 3/3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible MicroSD card Replacement, MicroSD card: 4 단계, 이미지 1/2 HTC Droid Incredible MicroSD card Replacement, MicroSD card: 4 단계, 이미지 2/2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible MicroSD card Replacement: 5 단계, 이미지 1/2 HTC Droid Incredible MicroSD card Replacement: 5 단계, 이미지 2/2
    • Pull the MicroSD card straight out of its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,810 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,095
