이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
필요한 것
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
다른 한 분이 해당 안내서를 완성하였습니다.
