주요 콘텐츠로 건너뛰기
HTC EVO 4G Speaker Replacement
필요한 것
  1. HTC EVO 4G Speaker Replacement, Battery: 1 단계, 이미지 1/2 HTC EVO 4G Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Speaker Replacement: 2 단계, 이미지 1/2 HTC EVO 4G Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Speaker Replacement: 3 단계, 이미지 1/1
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Speaker Replacement: 5 단계, 이미지 1/3 HTC EVO 4G Speaker Replacement: 5 단계, 이미지 2/3 HTC EVO 4G Speaker Replacement: 5 단계, 이미지 3/3
    • Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Speaker Replacement: 6 단계, 이미지 1/1
    • use plastic pic to gently pry our the speaker
    • be sure to have your replacement unit ready
결론
Sage Jurado
회원 가입일: 03/13/14
1,128 평판
안내서 4개 작성하였습니다
New Mexico State, Team 1-1, Easley Spring 2014 New Mexico State, Team 1-1, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 186
