소개
This is a guide on how to remove and replace the motherboard on an HTC Evo 3D. Replacement of the motherboard the motherboard can help fix numerous problems that are related to the motherboard. A few examples may include a faulty headphone jack, broken camera, broken charging port, over heating, etc. This guide includes the use of specific tools and possible hazards that may damage or harm the phone.
Remove the outer casing of the phone with your hands by prying and lifting at the latch.
With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
This will remove the inner case, and allow access into the inner portion of the phone.
다른 3명이 해당 안내서를 완성하였습니다.
