주요 콘텐츠로 건너뛰기
HTC Evo 3D Motherboard Replacement
필요한 것
  1. HTC Evo 3D Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 HTC Evo 3D Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 HTC Evo 3D Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HTC Evo 3D Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by gently pulling down on the bottom of the card.
  3. HTC Evo 3D Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HTC Evo 3D Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be sure not to rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Motherboard Replacement: 5 단계, 이미지 3개 중 1개 HTC Evo 3D Motherboard Replacement: 5 단계, 이미지 3개 중 2개 HTC Evo 3D Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pictured here is the motherboard.
    • Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
  6. HTC Evo 3D Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HTC Evo 3D Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HTC Evo 3D Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Next we will remove the vibration mechanism shown here.
    • Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
    • The piece should come loose easily.
  7. HTC Evo 3D Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HTC Evo 3D Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HTC Evo 3D Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • The next step is to disconnect all ribbons attached to the motherboard.
    • Begin by using tweezers to remove the plastic covering the ribbons.
    • Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
    • Unlock by lifting the white tab directly up.
    • The ribbons easily rip and require careful handling.
  8. HTC Evo 3D Motherboard Replacement: 8 단계, 이미지 2개 중 1개 HTC Evo 3D Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • At this point the motherboard is almost fully detached.
    • Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
  9. HTC Evo 3D Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HTC Evo 3D Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HTC Evo 3D Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Disconnect the two ribbons on the backside of the mother board using precision tweezers.
    • Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
    • The motherboard will now be free from the rest of the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Pope
회원 가입일: 08/26/15
441 평판
안내서 2개를 작성함
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 회원
USFT-MEIER-F15S14G20
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,003
