이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the outer casing of the phone with your hands by prying and lifting at the latch.
Remove the battery with your hands, lifting at the marked area.
Remove the SD card by gently pulling down on the bottom of the card.
Remove the four T5 screws using the corresponding screwdriver.
Remove the two J000 screws using the corresponding screwdriver.
With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
This will remove the inner case, and allow access into the inner portion of the phone.
Pictured here is the motherboard.
Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
Next we will remove the vibration mechanism shown here.
Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
The piece should come loose easily.
The next step is to disconnect all ribbons attached to the motherboard.
Begin by using tweezers to remove the plastic covering the ribbons.
Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
Unlock by lifting the white tab directly up.
At this point the motherboard is almost fully detached.
Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
Disconnect the two ribbons on the backside of the mother board using precision tweezers.
Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
The motherboard will now be free from the rest of the phone.
다른 3명이 해당 안내서를 완성하였습니다.
