주요 콘텐츠로 건너뛰기
HTC Evo 3D Speaker Replacement
필요한 것
  1. HTC Evo 3D Speaker Replacement, Speaker: 1 단계, 이미지 1/3 HTC Evo 3D Speaker Replacement, Speaker: 1 단계, 이미지 2/3 HTC Evo 3D Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Speaker Replacement: 2 단계, 이미지 1/2 HTC Evo 3D Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by pulling down on the bottom of the card.
  3. HTC Evo 3D Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the four T5 screws using the cooresponding screwdriver.
    • Remove the two J000 screws using the cooresponding screwdriver.
  4. HTC Evo 3D Speaker Replacement: 4 단계, 이미지 1/2 HTC Evo 3D Speaker Replacement: 4 단계, 이미지 2/2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • The marked part in the second photo is the speaker.
  5. HTC Evo 3D Speaker Replacement: 5 단계, 이미지 1/3 HTC Evo 3D Speaker Replacement: 5 단계, 이미지 2/3 HTC Evo 3D Speaker Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • The speaker can be loosened from its glue with the spudger.
    • Pry from the bottom with constant pressure to loosen one end of the speaker.
    • When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
  6. HTC Evo 3D Speaker Replacement: 6 단계, 이미지 1/1
    • With the old speaker removed, insert the new speaker in the same place.
    • When reinserting the new speaker, be sure that the golden contacts (As previously marked) are facing up.
결론
To reassemble your device, follow these instructions in reverse order but with a new speaker.
다른 한 분이 해당 안내서를 완성하였습니다.
James Burke
회원 가입일: 08/26/15
245 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 회원
USFT-MEIER-F15S14G20
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 347
