This is only a simple teardown to take out all components that can be easily switched out.
해당 분해도는 수리 안내서가 아닙니다. HTC Evo 3D 수리는 저희 서비스 설명서를 사용하십시오.
Remove the four T5 Torx screws.
Then remove the two Phillips screws.
*Very sorry for dark image*
Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
Begin from the bottom were the battery bay is, It is the easiest way.
Be careful of ribbons behind the plastic
Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
Tuck the ribbons in without bending or making tears in them.
Behind the main board is two more ribbon's.
Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
