필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four T5 Torx screws.
Then remove the two Phillips screws.
*Very sorry for dark image*
Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
Tuck the ribbons in without bending or making tears in them.
Behind the main board is two more ribbon's.
Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
