주요 콘텐츠로 건너뛰기
HTC Excalibur Motherboard Replacement
필요한 것
  1. HTC Excalibur Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Pry loose the metal cover near the camera lens, circled in the picture.
  2. HTC Excalibur Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover.
    • Gripping the battery by the bottom, lift and remove it from the phone.
  3. HTC Excalibur Motherboard Replacement: 3 단계, 이미지 3개 중 1개 HTC Excalibur Motherboard Replacement: 3 단계, 이미지 3개 중 2개 HTC Excalibur Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After loosening the case, remove it.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
  4. HTC Excalibur Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HTC Excalibur Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the one remaining screw in the logic board.
    • Unclip the wire that connects the back of the case to the logic board.
  5. HTC Excalibur Motherboard Replacement: 5 단계, 이미지 3개 중 1개 HTC Excalibur Motherboard Replacement: 5 단계, 이미지 3개 중 2개 HTC Excalibur Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Do this at an angle, lifting the side to the right of the SIM card instructions.
    • One of the strips is attached to the front of the case, and goes through the logic board. Be careful not to break this piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ian Mitchell
회원 가입일: 04/19/11
142 평판
안내서 5개를 작성함
Cal Poly, Team 25-27, Garner Spring 2011 Cal Poly, Team 25-27, Garner Spring 2011 회원
CPSU-GARNER-S11S25G27
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 2,368
