주요 콘텐츠로 건너뛰기
HTC Flyer Charging Port Replacement
필요한 것
  1. HTC Flyer Charging Port Replacement, Charging Port: 1 단계, 이미지 1/1
    • Remove the white portion of the top cover as shown. Push down on it to slide it off using just your fingers. Be careful not to break the clips holding it in place with removing it.
  2. HTC Flyer Charging Port Replacement: 2 단계, 이미지 1/3 HTC Flyer Charging Port Replacement: 2 단계, 이미지 2/3 HTC Flyer Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove the five Torx T5 screws.
  3. HTC Flyer Charging Port Replacement: 3 단계, 이미지 1/2 HTC Flyer Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove full frame on the back. A tip is to tape the volume button to the frame before removing it, as the volume button will fall out.
  4. HTC Flyer Charging Port Replacement: 4 단계, 이미지 1/2 HTC Flyer Charging Port Replacement: 4 단계, 이미지 2/2
    • Remove the plastic top cover of the motherboard.
  5. HTC Flyer Charging Port Replacement: 5 단계, 이미지 1/2 HTC Flyer Charging Port Replacement: 5 단계, 이미지 2/2
    • Remove four T5 Torx screws.
  6. HTC Flyer Charging Port Replacement: 6 단계, 이미지 1/3 HTC Flyer Charging Port Replacement: 6 단계, 이미지 2/3 HTC Flyer Charging Port Replacement: 6 단계, 이미지 3/3
    • Remove twelve of the connectors.
  7. HTC Flyer Charging Port Replacement: 7 단계, 이미지 1/2 HTC Flyer Charging Port Replacement: 7 단계, 이미지 2/2
    • Release the flex-screen touch cable. It is held in place with clips. Use the safe open pry tool to unclip it. Note that it will still be connected to the base and the motherboard.
  8. HTC Flyer Charging Port Replacement: 8 단계, 이미지 1/1
    • Flip the motherboard and the flex screen to the left.
  9. HTC Flyer Charging Port Replacement: 9 단계, 이미지 1/1
    • Release the two file cables attached to the motherboard.
  10. HTC Flyer Charging Port Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard. Note that the flex screen will not be removed with it and will remain attached to the tablet frame.
  11. HTC Flyer Charging Port Replacement: 11 단계, 이미지 1/3 HTC Flyer Charging Port Replacement: 11 단계, 이미지 2/3 HTC Flyer Charging Port Replacement: 11 단계, 이미지 3/3
  12. HTC Flyer Charging Port Replacement: 12 단계, 이미지 1/2 HTC Flyer Charging Port Replacement: 12 단계, 이미지 2/2
    • Remove the dock port flex cable. It will be tangled around other cables, so take care not to rip it while removing.
결론
Joshua Mahon
회원 가입일: 11/26/18
445 평판
안내서 3개 작성하였습니다
IUPUI, Team S5-G5, Wilson Fall 2018 IUPUI, Team S5-G5, Wilson Fall 2018 회원
IUPUI-WILSON-F18S5G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 11
전체 시간: 378
