소개
This repair is needed when your screen is scratched or not working properly. Be cautious of sharp metal parts in a device as they can cause bodily injury.
필요한 것
Apply pressure along the bottom of the white panel containing the camera and push upwards.
Remove the black protective piece of plastic by sliding it upwards.
Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
Remove the protective panel by sliding it upwards.
Gently unfold the black tape along the top that covers the cable attachment points.
Remove lower flex cable and LCD flex cable. They are attached and will be removed as one piece.
