주요 콘텐츠로 건너뛰기
HTC Fortress SIM Card Replacement
  1. HTC Fortress SIM Card Replacement, Battery: 1 단계, 이미지 1/2 HTC Fortress SIM Card Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
  2. HTC Fortress SIM Card Replacement: 2 단계, 이미지 1/2 HTC Fortress SIM Card Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pulling it away from the back of the phone.
  3. HTC Fortress SIM Card Replacement, SIM Card: 3 단계, 이미지 1/3 HTC Fortress SIM Card Replacement, SIM Card: 3 단계, 이미지 2/3 HTC Fortress SIM Card Replacement, SIM Card: 3 단계, 이미지 3/3
    • Insert the stylus into the small slot.
    • Use the stylus as a lever to push the sim card out of its fitting.
    • Use your finger to slide the card out the rest of the way.
결론
Lucas David
회원 가입일: 04/19/13
540 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 회원
CPSU-MANESS-S13S4G13
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 437
