주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Freestyle Screen Replacement
필요한 것
  1. HTC Freestyle Screen Replacement, Remove back cover: 1 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Remove back cover: 1 단계, 이미지 2개 중 2개
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
    댓글 쓰기
  2. HTC Freestyle Screen Replacement, Open plastic flap.: 2 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Open plastic flap.: 2 단계, 이미지 2개 중 2개
    • Fold the plastic flap open.
    댓글 쓰기
  3. HTC Freestyle Screen Replacement, Reveal the battery: 3 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Reveal the battery: 3 단계, 이미지 2개 중 2개
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
    댓글 쓰기
  4. HTC Freestyle Screen Replacement, Remove screws from plastic flap: 4 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
    댓글 쓰기
  5. HTC Freestyle Screen Replacement, Remove plastic flap from phone: 5 단계, 이미지 1개 중 1개
    • Once the screws are removed from the plastic flap, the piece should easily come out.
    댓글 쓰기
  6. HTC Freestyle Screen Replacement, Remove circuiting panel: 6 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Remove circuiting panel: 6 단계, 이미지 2개 중 2개
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
    댓글 쓰기
  7. HTC Freestyle Screen Replacement, Remove primary buttons: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
    댓글 쓰기
  8. HTC Freestyle Screen Replacement, Separate phone housing from electrical components: 8 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Separate phone housing from electrical components: 8 단계, 이미지 2개 중 2개
    • Rotate your HTC Freestyle so that the main screen is facing upward and toward you.
    • Use a plastic opening tool to pry the screen and electronic internals apart from the main phone housing.
    댓글 쓰기
  9. HTC Freestyle Screen Replacement, Remove screws from internal component: 9 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Remove screws from internal component: 9 단계, 이미지 2개 중 2개
    • Orient the component so that the battery compartment and camera are facing upwards.
    • Use the #00 Phillips screwdriver to remove the exterior screws that are holding the piece together.
    • There should be screws on both lateral sides of the phone as well as one screw in the top corner to the right of the camera
    댓글 쓰기
  10. HTC Freestyle Screen Replacement, Separate the internal component into two halves: 10 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Separate the internal component into two halves: 10 단계, 이미지 2개 중 2개
    • Once the screws are removed, the motherboard can be separated from the other components after prying open the gold-colored clamps hidden underneath the battery compartment.
    • Rotate the phone 180 degrees and pry the second clamp that is located on the other side of the component.
    • The motherboard will then easily be removed from the rest.
    댓글 쓰기
  11. HTC Freestyle Screen Replacement, Pry the screen from the front of the phone: 11 단계, 이미지 2개 중 1개 HTC Freestyle Screen Replacement, Pry the screen from the front of the phone: 11 단계, 이미지 2개 중 2개
    • Once the screen and motherboard are separated, use a plastic opening tool to pry along the edges of the touchscreen. **Note, the use of a heat gun/heating element will help loosen the adhesive from behind the screen to make prying less physically straining.
    • The screen should now be fully removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jonathan Franco
회원 가입일: 10/07/14
98 평판
안내서 1개를 작성함
USF Tampa, Team 8-3, Leahy Fall 2014 USF Tampa, Team 8-3, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 23
전체 시간: 703
