주요 콘텐츠로 건너뛰기
HTC HD2 Midframe Replacement
필요한 것
  1. HTC HD2 Midframe Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Midframe Replacement: 2 단계, 이미지 2개 중 1개 HTC HD2 Midframe Replacement: 2 단계, 이미지 2개 중 2개
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Midframe Replacement, Midframe: 3 단계, 이미지 2개 중 1개 HTC HD2 Midframe Replacement, Midframe: 3 단계, 이미지 2개 중 2개
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Midframe Replacement: 4 단계, 이미지 2개 중 1개 HTC HD2 Midframe Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Sam Luedloff
회원 가입일: 04/12/11
727 평판
안내서 3개를 작성함
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G55
5 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 9,029
