주요 콘텐츠로 건너뛰기
HTC HD2 Phone Speaker Replacement
필요한 것
  1. HTC HD2 Phone Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Phone Speaker Replacement: 2 단계, 이미지 1/2 HTC HD2 Phone Speaker Replacement: 2 단계, 이미지 2/2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Phone Speaker Replacement, Midframe: 3 단계, 이미지 1/2 HTC HD2 Phone Speaker Replacement, Midframe: 3 단계, 이미지 2/2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Phone Speaker Replacement: 4 단계, 이미지 1/2 HTC HD2 Phone Speaker Replacement: 4 단계, 이미지 2/2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Phone Speaker Replacement, Phone Speaker: 5 단계, 이미지 1/1
    • With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
    • The speaker should be easily popped out of place with a small amount of force
  6. HTC HD2 Phone Speaker Replacement: 6 단계, 이미지 1/1
    • Congratulations! The speaker is now removed and can be replaced or repaired.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Puchalski
회원 가입일: 04/26/11
813 평판
안내서 5개 작성하였습니다
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G55
5 회원들
안내서 16개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 6,874
