주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Hero Back Case Replacement
필요한 것
  1. HTC Hero Back Case Replacement, Back Case: 1 단계, 이미지 1개 중 1개
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Back Case Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Back Case Replacement: 3 단계, 이미지 1개 중 1개
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Back Case Replacement: 4 단계, 이미지 2개 중 1개 HTC Hero Back Case Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
결론
작성자
7다른 기여자 명과 함께
Max Brown
회원 가입일: 01/23/12
139 평판
안내서 4개를 작성함
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 70
전체 시간: 2,492
