주요 콘텐츠로 건너뛰기
HTC Hero Motherboard Replacement
필요한 것
  1. HTC Hero Motherboard Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Motherboard Replacement: 4 단계, 이미지 1/2 HTC Hero Motherboard Replacement: 4 단계, 이미지 2/2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 HTC Hero Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
  6. HTC Hero Motherboard Replacement: 6 단계, 이미지 1/2 HTC Hero Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  7. HTC Hero Motherboard Replacement: 7 단계, 이미지 1/2 HTC Hero Motherboard Replacement: 7 단계, 이미지 2/2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
결론
Rosalind Villalvazo
회원 가입일: 01/23/12
100 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,569
