주요 콘텐츠로 건너뛰기
HTC Hero Trackball Replacement
필요한 것
  1. HTC Hero Trackball Replacement, Back Case: 1 단계, 이미지 1/1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Trackball Replacement: 2 단계, 이미지 1/1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Trackball Replacement: 3 단계, 이미지 1/1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Trackball Replacement: 4 단계, 이미지 1/2 HTC Hero Trackball Replacement: 4 단계, 이미지 2/2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Trackball Replacement, Trackball: 5 단계, 이미지 1/2 HTC Hero Trackball Replacement, Trackball: 5 단계, 이미지 2/2
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
  6. HTC Hero Trackball Replacement: 6 단계, 이미지 1/2 HTC Hero Trackball Replacement: 6 단계, 이미지 2/2
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
  7. HTC Hero Trackball Replacement: 7 단계, 이미지 1/2 HTC Hero Trackball Replacement: 7 단계, 이미지 2/2
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
  8. HTC Hero Trackball Replacement: 8 단계, 이미지 1/2 HTC Hero Trackball Replacement: 8 단계, 이미지 2/2
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
  9. HTC Hero Trackball Replacement: 9 단계, 이미지 1/3 HTC Hero Trackball Replacement: 9 단계, 이미지 2/3 HTC Hero Trackball Replacement: 9 단계, 이미지 3/3
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Max Brown
회원 가입일: 01/23/12
139 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G26
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 1,529
