주요 콘텐츠로 건너뛰기
HTC Incredible 2 Battery Replacement
  1. HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: 1 단계, 이미지 1/2 HTC Incredible 2 Battery Replacement, Disassembling HTC Incredible 2 Back Panel: 1 단계, 이미지 2/2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 Battery Replacement: 4 단계, 이미지 1/2 HTC Incredible 2 Battery Replacement: 4 단계, 이미지 2/2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan Morsch
회원 가입일: 04/26/14
394 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G53
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 593
