주요 콘텐츠로 건너뛰기
  1. Use a plastic opening tool to take off the rear panel.
    • Use a plastic opening tool to take off the rear panel.
  2. Use a curved metal spudger to remove  the rear panel.
    • Use a curved metal spudger to remove the rear panel.
    • Always try using a nylon spudger or plastic opening tool first; metal spudgers are not ESD-safe and can potentially damage your device.
  3. Push up to remove the back cover.
    • Push up to remove the back cover.
  4. Remove the earpiece speaker connector using the tweezers. Pry out the speaker using a nylon spudger.
    • Remove the earpiece speaker connector using the tweezers.
    • Pry out the speaker using a nylon spudger.
결론
MOHANAD
회원 가입일: 2016년 06월 27일
132 평판
안내서 1개 작성함
Eastern Washington University, Team 1-3, Rowley SU 2016 Eastern Washington University, Team 1-3, Rowley SU 2016 회원
EWU-ROWLEY-SU16S1G3
4 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 167
