이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push down firmly on the back cover of the phone and pull it back.
It will only slide back about half an inch, after that you can lift it up.
Take out the battery using the two tabs at the upper right and upper left corner of the battery.
Take out the simcard by putting your finger on the revealing bit of the card and pulling it out towards you.
If it doesn't work immediately, try using the small open space near the bottom of the simcard to partially push it forward.
다른 3명이 해당 안내서를 완성하였습니다.
