주요 콘텐츠로 건너뛰기
HTC Magic Speaker Replacement
필요한 것
  1. HTC Magic Speaker Replacement, Speaker: 1 단계, 이미지 1/3 HTC Magic Speaker Replacement, Speaker: 1 단계, 이미지 2/3 HTC Magic Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. HTC Magic Speaker Replacement: 2 단계, 이미지 1/1
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. HTC Magic Speaker Replacement: 3 단계, 이미지 1/2 HTC Magic Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  4. HTC Magic Speaker Replacement: 5 단계, 이미지 1/2 HTC Magic Speaker Replacement: 5 단계, 이미지 2/2
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
결론
LucasJV
회원 가입일: 05/18/10
735 평판
안내서 3개 작성하였습니다
Verheij.co Verheij.co 회원
Business
1 회원
안내서 5개 작성하였습니다
댓글 한 개
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 10,698
