주요 콘텐츠로 건너뛰기
HTC Maple 100 Internal Ear Speaker Replacement
필요한 것
  1. HTC Maple 100 Internal Ear Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Internal Ear Speaker Replacement: 2 단계, 이미지 1/1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Internal Ear Speaker Replacement: 3 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 3 단계, 이미지 2/2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 4 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 4 단계, 이미지 2/2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Internal Ear Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Internal Ear Speaker Replacement: 6 단계, 이미지 1/3 HTC Maple 100 Internal Ear Speaker Replacement: 6 단계, 이미지 2/3 HTC Maple 100 Internal Ear Speaker Replacement: 6 단계, 이미지 3/3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 7 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Internal Ear Speaker Replacement: 8 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 8 단계, 이미지 2/2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Internal Ear Speaker Replacement: 9 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 9 단계, 이미지 2/2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Internal Ear Speaker Replacement: 10 단계, 이미지 1/3 HTC Maple 100 Internal Ear Speaker Replacement: 10 단계, 이미지 2/3 HTC Maple 100 Internal Ear Speaker Replacement: 10 단계, 이미지 3/3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Internal Ear Speaker Replacement: 11 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 11 단계, 이미지 2/2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Internal Ear Speaker Replacement: 12 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 12 단계, 이미지 2/2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 Internal Ear Speaker Replacement, Internal Ear Speaker: 13 단계, 이미지 1/1
    • Locate the internal speaker at the top center of the phone.
  14. HTC Maple 100 Internal Ear Speaker Replacement: 14 단계, 이미지 1/2 HTC Maple 100 Internal Ear Speaker Replacement: 14 단계, 이미지 2/2
    • Using the plastic opening tool, carefully pry out the internal speaker.
결론
Alyssa Thompson
회원 가입일: 10/04/11
11 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 회원
CPSU-MANESS-F11S20G29
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 759
