주요 콘텐츠로 건너뛰기
소개
Broken screen getting you down? Follow along to restore your mood.
  1. Before you proceed, discharge your device battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Power off the device. Locate the SD Card/SIM Card cover flap on the left side of the device.
    • Before you proceed, discharge your device battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off the device.
    • Locate the SD Card/SIM Card cover flap on the left side of the device.
    • Upon opening the cover flap you will find slots for SD Card and the SIM Card. Carefully remove these items if your device has them and set them aside.
    • Lift on the back cover to begin the removal process. Continue removing the back cover by working along the edge. Once removed set aside the back cover.
  2. Remove the five 3.5mm T4 Torx Screws.
    • Remove the five 3.5mm T4 Torx Screws.
    • Remove the two 4.5mm #00 Phillips screws.
    • Please be aware of the sticker below the battery. Following this guide past this point may void your device's warranty.
  3. Place a plastic opening tool along the seam of the front plate and back plate. Run the opening tool along the seam while prying slightly in order to pop the plastic clips away from the front plate. Once one or two clips have popped away you may begin to use your free hand to apply additional pressure while continuing to apply prying pressure as well with the opening tool.
    • Place a plastic opening tool along the seam of the front plate and back plate. Run the opening tool along the seam while prying slightly in order to pop the plastic clips away from the front plate.
    • Once one or two clips have popped away you may begin to use your free hand to apply additional pressure while continuing to apply prying pressure as well with the opening tool.
    • Apply constant but controlled pressure while separating the front from the back. Damage may occur if using excessive pressure while separating the plates along the seam.
  4. Continue working your way around the seam between the two parts and eventually you will be able to separate the entirety of the backplate revealing the internals of the device.
    • Continue working your way around the seam between the two parts and eventually you will be able to separate the entirety of the backplate revealing the internals of the device.
  5. Note the position of the battery connector.
    • Note the position of the battery connector.
    • We will be prying on the battery shortly which may cause accidental pressure to be place on this connector. Be careful not to damage this connector while removing the battery.
  6. Place the plastic opening tool to the side of the battery and work underneath the battery. Slowly and gently pry the battery away from the device removing the battery from the adhesive underneath. After breaking away one side of the battery from the adhesive strips you can take advantage of the additional leverage by using your hand to break free from the adhesive on the opposite side.
    • Place the plastic opening tool to the side of the battery and work underneath the battery. Slowly and gently pry the battery away from the device removing the battery from the adhesive underneath.
    • After breaking away one side of the battery from the adhesive strips you can take advantage of the additional leverage by using your hand to break free from the adhesive on the opposite side.
    • You will hear cracking and popping as the battery breaks loose from the adhesive strips underneath. This is normal and to be expected.
  7. After prying the battery free from the device the connector can be removed by pulling directly up away from the device.
    • After prying the battery free from the device the connector can be removed by pulling directly up away from the device.
  8. Place the plastic opening tool under the speaker and pry it away from the device.
    • Place the plastic opening tool under the speaker and pry it away from the device.
  9. Remove the antenna connector from the bottom logic board by using tweezers. Grasp the bottom of the metal connector and pull away towards the top of the connector.
    • Remove the antenna connector from the bottom logic board by using tweezers. Grasp the bottom of the metal connector and pull away towards the top of the connector.
    • The connector should come free easily if done correctly.
  10. Remove the tape covering the connector that holds the ribbon cable to the lower logic board in place.
    • Remove the tape covering the connector that holds the ribbon cable to the lower logic board in place.
    • Use tweezers to pull the ribbon cable free of the connector. Pulling directly away from the connector apply even and constant pressure until the cable slides free.
  11. Note the position of the three plastic clips holding the lower logic board in place. Place the plastic opening tool along one side and slowly begin to pry up. The board will flex slightly allowing it to pass by and free of the plastic clips.
    • Note the position of the three plastic clips holding the lower logic board in place.
    • Place the plastic opening tool along one side and slowly begin to pry up. The board will flex slightly allowing it to pass by and free of the plastic clips.
  12. Using the tweezers, remove the antenna connection. Grab the connector by the base and pull towards the head of the connector.
    • Using the tweezers, remove the antenna connection. Grab the connector by the base and pull towards the head of the connector.
  13. Remove the tape that sits on top of the left connector. Place the tweezers around the ribbon cable and apply even pressure away from the connector to disconnect the cable.
    • Remove the tape that sits on top of the left connector.
    • Place the tweezers around the ribbon cable and apply even pressure away from the connector to disconnect the cable.
  14. Remove the tape that sits on top of the right connector. Place the tweezers around the ribbon cable and apply even pressure away from the connector to disconnect the cable.
    • Remove the tape that sits on top of the right connector.
  15. Using the tweezers or another small pointed tool, place the tip under the edge of the round disk-like component on the left side of the device. Apply a small amount of pressure to the edge of the component to dislodge it.
    • Using the tweezers or another small pointed tool, place the tip under the edge of the round disk-like component on the left side of the device. Apply a small amount of pressure to the edge of the component to dislodge it.
  16. Place the plastic opening tool along the edge of the components and lightly pry these components out of their slots.
    • Place the plastic opening tool along the edge of the components and lightly pry these components out of their slots.
    • Ensure that you don't damage these components. They should require little force to dislodge.
  17. Note the location of the plastic clips. Place the plastic opening tool along the top of the upper logic board. Apply even gentle pressure to remove the logic board from the rest of the device.
    • Note the location of the plastic clips.
    • Place the plastic opening tool along the top of the upper logic board. Apply even gentle pressure to remove the logic board from the rest of the device.
  18. Lift the tape securing the upper speaker. Apply gentle pressure with the tweezers to dislodge the speaker and then lift away from the rest of the device.
    • Lift the tape securing the upper speaker.
    • Apply gentle pressure with the tweezers to dislodge the speaker and then lift away from the rest of the device.
  19. Transfer any items that were not a part of your new display assembly from the old to the new.
    • Transfer any items that were not a part of your new display assembly from the old to the new.
  20. When re-assembling the device. Ensure that the highlighted connector on the back side of the upper logic board assembly is seated properly.
    • When re-assembling the device. Ensure that the highlighted connector on the back side of the upper logic board assembly is seated properly.
결론
Steve Gilland
회원 가입일: 2017년 01월 18일
1,019 평판
안내서 10개 작성하였습니다
Arkansas State University, Team 1-3, Chamberlain Spring 2017 Arkansas State University, Team 1-3, Chamberlain Spring 2017 회원
ARSU-CHAMBERLAIN-S17S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 836
