주요 콘텐츠로 건너뛰기
이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 1 단계, 이미지 1/3 : 1 단계, 이미지 2/3 : 1 단계, 이미지 3/3
    • Before you proceed, discharge your device battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off the device.
    • Locate the SD Card/SIM Card cover flap on the left side of the device.
    • Upon opening the cover flap you will find slots for SD Card and the SIM Card. Carefully remove these items if your device has them and set them aside.
    • Lift on the back cover to begin the removal process. Continue removing the back cover by working along the edge. Once removed set aside the back cover.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 2 단계, 이미지 1/1
    • Remove the five 3.5mm T4 Torx Screws.
    • Remove the two 4.5mm #00 Phillips screws.
    • Please be aware of the sticker below the battery. Following this guide past this point may void your device's warranty.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 3 단계, 이미지 1/2 : 3 단계, 이미지 2/2
    • Place a plastic opening tool along the seam of the front plate and back plate. Run the opening tool along the seam while prying slightly in order to pop the plastic clips away from the front plate.
    • Once one or two clips have popped away you may begin to use your free hand to apply additional pressure while continuing to apply prying pressure as well with the opening tool.
    • Apply constant but controlled pressure while separating the front from the back. Damage may occur if using excessive pressure while separating the plates along the seam.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 4 단계, 이미지 1/1
    • Continue working your way around the seam between the two parts and eventually you will be able to separate the entirety of the backplate revealing the internals of the device.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 5 단계, 이미지 1/1
    • Note the position of the battery connector.
    • We will be prying on the battery shortly which may cause accidental pressure to be place on this connector. Be careful not to damage this connector while removing the battery.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 6 단계, 이미지 1/2 : 6 단계, 이미지 2/2
    • Place the plastic opening tool to the side of the battery and work underneath the battery. Slowly and gently pry the battery away from the device removing the battery from the adhesive underneath.
    • After breaking away one side of the battery from the adhesive strips you can take advantage of the additional leverage by using your hand to break free from the adhesive on the opposite side.
    • You will hear cracking and popping as the battery breaks loose from the adhesive strips underneath. This is normal and to be expected.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 7 단계, 이미지 1/1
    • After prying the battery free from the device the connector can be removed by pulling directly up away from the device.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 8 단계, 이미지 1/1
    • Remove the antenna connector from the bottom logic board by using tweezers. Grasp the bottom of the metal connector and pull away towards the top of the connector.
    • The connector should come free easily if done correctly.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 9 단계, 이미지 1/1
    • Remove the tape covering the connector that holds the ribbon cable to the lower logic board in place.
    • Use tweezers to pull the ribbon cable free of the connector. Pulling directly away from the connector apply even and constant pressure until the cable slides free.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 10 단계, 이미지 1/2 : 10 단계, 이미지 2/2
    • Note the position of the three plastic clips holding the lower logic board in place.
    • Place the plastic opening tool along one side and slowly begin to pry up. The board will flex slightly allowing it to pass by and free of the plastic clips.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    : 11 단계, 이미지 1/1
    • When re-seating the board, ensure that all plastic clips are holding the board in place. You may need to shift the board to the left or right to do so.
    • When re-assembling device ensure that the antenna wire is routed correctly.
결승점
Steve Gilland
회원 가입일: 01/18/17
1,043 평판
안내서 10개 작성하였습니다
Arkansas State University, Team 1-3, Chamberlain Spring 2017 Arkansas State University, Team 1-3, Chamberlain Spring 2017 회원
ARSU-CHAMBERLAIN-S17S1G3
3 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 383
