주요 콘텐츠로 건너뛰기
HTC One M8 Bottom Speaker Replacement
필요한 것
  1. HTC One M8 Bottom Speaker Replacement, SIM Card: 1 단계, 이미지 1/2 HTC One M8 Bottom Speaker Replacement, SIM Card: 1 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Bottom Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Bottom Speaker Replacement, MicroSD Card: 3 단계, 이미지 1/2 HTC One M8 Bottom Speaker Replacement, MicroSD Card: 3 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Bottom Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Bottom Speaker Replacement, Rear Case: 5 단계, 이미지 1/2 HTC One M8 Bottom Speaker Replacement, Rear Case: 5 단계, 이미지 2/2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Bottom Speaker Replacement: 6 단계, 이미지 1/3 HTC One M8 Bottom Speaker Replacement: 6 단계, 이미지 2/3 HTC One M8 Bottom Speaker Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Bottom Speaker Replacement: 7 단계, 이미지 1/2 HTC One M8 Bottom Speaker Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Bottom Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Bottom Speaker Replacement: 9 단계, 이미지 1/3 HTC One M8 Bottom Speaker Replacement: 9 단계, 이미지 2/3 HTC One M8 Bottom Speaker Replacement: 9 단계, 이미지 3/3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
  10. HTC One M8 Bottom Speaker Replacement, Motherboard: 10 단계, 이미지 1/2 HTC One M8 Bottom Speaker Replacement, Motherboard: 10 단계, 이미지 2/2
    • Remove the two silver 2 mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
  11. HTC One M8 Bottom Speaker Replacement: 11 단계, 이미지 1/3 HTC One M8 Bottom Speaker Replacement: 11 단계, 이미지 2/3 HTC One M8 Bottom Speaker Replacement: 11 단계, 이미지 3/3
    • Use a spudger to disconnect the two (four) antenna cables.
    • Use the tip of a spudger to disconnect the seven ZIF connectors.
    • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
  12. HTC One M8 Bottom Speaker Replacement: 12 단계, 이미지 1/1
    • Remove three silver 3mm screws using T5 screwdriver.
  13. HTC One M8 Bottom Speaker Replacement: 13 단계, 이미지 1/3 HTC One M8 Bottom Speaker Replacement: 13 단계, 이미지 2/3 HTC One M8 Bottom Speaker Replacement: 13 단계, 이미지 3/3
    • Use an iOpener or a heat gun to loosen up the adhesive securing the motherboard to the display assembly.
    • Use a plastic opening tool to gently pry the motherboard free of the display assembly.
    • At this point, the bottom speaker is still attached to the motherboard. If you are only replacing the motherboard, refer to the bottom speaker guide to swap your existing speaker to the new motherboard.
  14. HTC One M8 Bottom Speaker Replacement, Bottom Speaker: 14 단계, 이미지 1/3 HTC One M8 Bottom Speaker Replacement, Bottom Speaker: 14 단계, 이미지 2/3 HTC One M8 Bottom Speaker Replacement, Bottom Speaker: 14 단계, 이미지 3/3
    • Use an iOpener to loosen up the adhesive securing the bottom speaker to the motherboard.
    • Use a pair of tweezers to gently remove the bottom speaker from the motherboard.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Michael Gonzalez
회원 가입일: 04/14/15
4,409 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 회원
CPSU-MANESS-S15S5G9
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 11,792
