주요 콘텐츠로 건너뛰기
HTC One M9 MicroSD Card Replacement
필요한 것
  1. HTC One M9 MicroSD Card Replacement, MicroSD Card: 1 단계, 이미지 3개 중 1개 HTC One M9 MicroSD Card Replacement, MicroSD Card: 1 단계, 이미지 3개 중 2개 HTC One M9 MicroSD Card Replacement, MicroSD Card: 1 단계, 이미지 3개 중 3개
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Geoff Wacker
회원 가입일: 09/30/13
92,026 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 1,284
