주요 콘텐츠로 건너뛰기
HTC One M9 Motherboard Replacement
필요한 것
  1. HTC One M9 Motherboard Replacement, MicroSD Card: 1 단계, 이미지 1/3 HTC One M9 Motherboard Replacement, MicroSD Card: 1 단계, 이미지 2/3 HTC One M9 Motherboard Replacement, MicroSD Card: 1 단계, 이미지 3/3
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
  2. HTC One M9 Motherboard Replacement, SIM Card: 2 단계, 이미지 1/3 HTC One M9 Motherboard Replacement, SIM Card: 2 단계, 이미지 2/3 HTC One M9 Motherboard Replacement, SIM Card: 2 단계, 이미지 3/3
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • Press to eject the tray.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  3. HTC One M9 Motherboard Replacement, Rear Case: 3 단계, 이미지 1/3 HTC One M9 Motherboard Replacement, Rear Case: 3 단계, 이미지 2/3 HTC One M9 Motherboard Replacement, Rear Case: 3 단계, 이미지 3/3
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
    Be sure to remove the SIM tray and memory card tray prior to removing back case! Bent mine because that step was missing.
    cameronb - 답글
    The black plastic piece that runs across the top is very thin and is stuck on with very strong tape.
    SMcC21985 - 답글
  4. HTC One M9 Motherboard Replacement: 4 단계, 이미지 1/3 HTC One M9 Motherboard Replacement: 4 단계, 이미지 2/3 HTC One M9 Motherboard Replacement: 4 단계, 이미지 3/3
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
    The SIM Card and SD Card's need to be removed before the case will come apart.
    Andrew Froude - 답글
    I found a video showing someone using a 2 to 3 inch length scraper razor blade around the perimeter. On my second HTCM9 battery swap I found that leading with a square tipped X-Acto blade to begin the opening, and leaving the trailing, “already opened” gap “wedged” open with the scraper blade helped smoothly open from top (IR header) to bottom (micro USB charger port). A conventional spudger pries open too quickly and can damage and misshape the LCD’s soft bezel. The bezel surround is a much softer compound than the rear case. You can work the rear case loose by gently prying the back’s perimeter outward and occasionally inward as you progress. There are four tabs on the LCD assembly (i.e. nearby and under the pliers in step 5) on each side that protrude into the rear case. Push in toward the back, and pry outward on the back case seam around the vicinity of the tabs. This action provides clearance for the tab to loose from the case tab slot.
    Michael K - 답글
  5. HTC One M9 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use a pair of tweezers to get underneath the white and blue cable connectors and gently push them upwards to disconnect them.
    Blue coax cable.. what does it do?
    Yusuf Koçaslan - 답글
  6. HTC One M9 Motherboard Replacement: 6 단계, 이미지 1/2 HTC One M9 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the two 1.5 mm screws that secure the battery connector to the motherboard, using a Phillips #00 screwdriver.
    • Use a spudger to gently pry up the battery connector from its socket.
    • Do not apply pressure to the socket.
    When reassembling the phone, be sure to attach the battery connector correctly before screwing it down. It has a rectangular connector that may not seat correctly if simply screwed down.
    Jay Clark - 답글
    On my new battery the connector was not aligned precisely so the battery was not connected properly to the motherboard after screwing it in. The connector is supposed to hold on it’s own without the screws. If the connector does not hold to the motherboard without the screws, make sure that the connector is actually plugged in properly and only screw it in once it holds by itself.
    Gerrit Addiks - 답글
  7. HTC One M9 Motherboard Replacement: 7 단계, 이미지 1/2 HTC One M9 Motherboard Replacement: 7 단계, 이미지 2/2
    • Peel back the Kapton tape from the ZIF connectors.
    • Use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and gently slide the cables out.
    Lift up on the white portion of the connector
    Jarred Goar - 답글
  8. HTC One M9 Motherboard Replacement: 8 단계, 이미지 1/3 HTC One M9 Motherboard Replacement: 8 단계, 이미지 2/3 HTC One M9 Motherboard Replacement: 8 단계, 이미지 3/3
    • Using the tweezers, carefully lift the tape covering the electrical strip, as shown in the picture.
    • Be gentle when lifting the tape as it can tear easily.
    • Use a spudger or your fingernail to lift the hinged retainer clip on the ZIF connector, and slide the cable out.
    Mine did not have the piece of tape.
    SMcC21985 - 답글
  9. HTC One M9 Motherboard Replacement: 9 단계, 이미지 1/3 HTC One M9 Motherboard Replacement: 9 단계, 이미지 2/3 HTC One M9 Motherboard Replacement: 9 단계, 이미지 3/3
    • Peel back the Kapton tape from the remaining three ZIF connectors, then use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and slide the cables out from each.
    • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
    For the featured ZIF header in step 10, which originates from under the circuit board, after liberating the yellow-clear tape I used a “Plackers” dental flosser “pointed end” to carefully lift up from under the ZIF ribbon.
    Michael K - 답글
    the third connector what is that one for? my screen was sometimes flicker and that connector is loose from underneath the motherboard
    Sugar Bomb Gaming - 답글
  10. HTC One M9 Motherboard Replacement: 10 단계, 이미지 1/3 HTC One M9 Motherboard Replacement: 10 단계, 이미지 2/3 HTC One M9 Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the dual LED flash cover with a pair of tweezers. The cover is held on with a small amount of adhesive.
    • Using a heated pair of tweezers would ease the removal of flash cover, as the heat helps weaken the adhesive .
    • Remove the cover using a minimum amount of force. The flash cover may be glued to the antenna cable(s) below.
    • Use a pair of tweezers to disconnect the two antenna cables near the camera.
    • Some models of this phone will have only one antenna cable at this location.
    • Disconnect the antenna cable near the bottom right of the phone.
  11. HTC One M9 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the three 4 mm T5 Torx screws that secure the motherboard.
    Great guide just one crucial warning missing! When removing the battery which is underneath the power/SD/volume cable make sure you see that and carefully remove the battery without tearing it apart! Had to learn the hard way. Fortunately it's replaceable..
    Charles Vheru - 답글
  12. HTC One M9 Motherboard Replacement: 12 단계, 이미지 1/2 HTC One M9 Motherboard Replacement: 12 단계, 이미지 2/2
    • Use a pair of tweezers to lift the vibrator out of its slot.
    • Avoid damaging the wires connecting the vibrator to the motherboard. Use the minimum amount of force.
    • Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
    • Refer to the iOpener Instructions for further info.
    • Use a plastic opening tool, or a spudger, along the edges of the case to gently pry the motherboard out of the case.
    • Gently lift the motherboard out of the case, beginning from the top corner (near the camera).
    Mine did not have any adhesive.
    SMcC21985 - 답글
결론
Continue to a specific replacement guide for further instructions on replacing what you wish to replace in you HTC One M9.
다른 15명이 해당 안내서를 완성하였습니다.
Rodolfo Meave
회원 가입일: 04/14/15
1,434 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-16, Maness Spring 2015 Cal Poly, Team 6-16, Maness Spring 2015 회원
CPSU-MANESS-S15S6G16
4 회원들
안내서 16개 작성하였습니다
댓글 5개
Not really that hard!
Well, i repair phones everyday and HTC is always a difficult brand, but I would rate the M7 as harder to repair than the M9.
The only part that should be very very remarked is while lifting up the motherboard, if you don't warm the adhesive it will be very difficult to get it out of the case, yesterday I did one and broke 1 led of the notifications leds!
Rafael B - 답글
do u have any m9 motherboard for sale? I am searching for one
Abdin Syakirin -
No sir, i don’t sell any parts for any phone.
After messing with the HTC 10 i must say that’s my most difficult HTC to do as of yet, a nightmare!
Rafael B -
I own an HTC M9 and I need its motherboard. Any chance you could tell me where to find it?
yelgaonkar ketaki - 답글
Anbody know where is located Gps Antenna of htc M9 plus. Pkease help me.in map my location blue dot is not accurate correctly. Sometng problem in hardware gps Antenna like.
shamsujezias - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 11,102
