소개
Use this guide to replace the back case on your HTC One Max.
부품
지정된 부품이 없습니다.
Lift back cover while pressing highlighted release switch towards the center of the phone.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
The "Tools" section of the guide lists a Y0 screwdriver as required but in the steps it says Y1. Now I have a Y0 screwdriver i can't do anything with and i have to order a Y1. Hopefully that is accurate.
Soooo... unless your HTC One MAX is completely different from the Sprint one i'm trying to replace the back on, both the Y0 and Y1 screw drivers are WRONG for this phone. They are both a bit too big to work on the screws. Now I've bought TWO screw drivers from you guys that were incorrect. Guess i'm gonna need to go out and buy a tri-wing screw driver set.
khaydin -
You need a #Y00 which is smaller then a #Y0 and #Y1 .
The site tells you to use a #Y00 and it does work for any HTC One Max
