소개
In this guide you willl learn how to replace a microphone in a HTC One Max.
필요한 것
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 4개
Microphone in the article, battery in the title.
How to change LCD screen for this model?
