소개
Use this guide to replace a broken or defective IR blaster.
필요한 것
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
다른 3명이 해당 안내서를 완성하였습니다.
