소개
Give your phone a battery boost by replacing the battery in your HTC One S.
부품
지정된 부품이 없습니다.
Using the pointed end of a spudger, lift the battery cable and release the connector.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 4개
Hello thank you for the guide. Getting the backplate off was tough. When assembling a little rubber block was loose. this goes next to the motor
J Shepherd - 답글
