주요 콘텐츠로 건너뛰기
소개
If your motherboard is fried, replace it using this guide.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. If you don't have a microwave, follow this step to heat your iOpener in boiling water. Fill a pot or pan with enough water to fully submerge an iOpener.
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. Handling it by the tag, place the heated iOpener across the bottom casing.
    • Handling it by the tag, place the heated iOpener across the bottom casing.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the casing.
  6. Gently place an opening pick in the corner of the gap between the bottom casing and rear case. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go. Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
    • Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
    • Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
  7. Use your fingers to pull the bottom casing off the rest of the phone.
    • Use your fingers to pull the bottom casing off the rest of the phone.
  8. Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing. Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
    • Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
  9. Use your fingers to pull the top casing off of the rest of the phone.
    • Use your fingers to pull the top casing off of the rest of the phone.
  10. Remove the following screws holding the rear case to the rest of the phone:
    • Remove the following screws holding the rear case to the rest of the phone:
    • Two 3.15 mm Phillips #00 screws
    • One 4.15 Torx T5 screw
    • One 4 mm Torx T5 screw
  11. Place your fingers on either side of the phone and gently push up on the rear case. It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there. It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there.
    • Place your fingers on either side of the phone and gently push up on the rear case.
    • It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there.
  12. Pull the rear case away from the rest of the phone with your hands.
    • Pull the rear case away from the rest of the phone with your hands.
  13. Using the pointed end of a spudger, lift the battery cable and release the connector. Using the pointed end of a spudger, lift the battery cable and release the connector.
    • Using the pointed end of a spudger, lift the battery cable and release the connector.
  14. Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive. Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
    • Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
  15. Remove the battery from the phone.
    • Remove the battery from the phone.
  16. Remove the three 3.15mm Phillips #00 screws from the turquoise case.
    • Remove the three 3.15mm Phillips #00 screws from the turquoise case.
  17. Using a plastic opening tool, lift the turquoise case from the end near the headphone jack. Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
    • Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
  18. Remove the turquoise cover from the phone.
    • Remove the turquoise cover from the phone.
  19. A camera filter is now free to move, so remove it using tweezers. A camera filter is now free to move, so remove it using tweezers.
    • A camera filter is now free to move, so remove it using tweezers.
  20. Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors. Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors. Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
    • Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
  21. Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector. Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
    • Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
  22. Use the pointed edge of a spudger to work the ZIF cable out of its connector. To do this, you may have to slowly work both sides until the whole cable is released. To do this, you may have to slowly work both sides until the whole cable is released.
    • Use the pointed edge of a spudger to work the ZIF cable out of its connector.
    • To do this, you may have to slowly work both sides until the whole cable is released.
  23. Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
    • Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
  24. Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard. Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
    • Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
  25. Remove the 3.15 mm Phillips #00 screw from the motherboard.
    • Remove the 3.15 mm Phillips #00 screw from the motherboard.
  26. Remove the motherboard from the rest of the phone. Remove the motherboard from the rest of the phone.
    • Remove the motherboard from the rest of the phone.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Jay Miley
회원 가입일: 2014년 04월 22일
4,730 평판
안내서 13개 작성하였습니다
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G55
4 회원들
안내서 31개 작성하였습니다
댓글 한 개
IOpener wasn't necessary, with the plastic opening tool i was able to easily remove the bottom cover. Also, it's real easy to crush/squash the battery with the prying tool.
edgarzaf - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 4,211
