이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
냄비나 팬에 iOpener가 완전히 잠길 정도로 충분한 물을 채우세요.
물이 끓을 때까지 가열하세요. 불을 끄세요.
iOpener를 뜨거운 물에 2~3분간 담그세요. iOpener가 물에 완전히 잠겼는지 확인합니다.
집게를 사용하여 뜨거운 물에서 가열된 아이오페너를 꺼내세요.
수건으로 iOpener를 완전히 말리세요.
iOpener를 사용할 준비가 되었습니다! iOpener를 재가열해야 한다면 물을 끓인 후 불을 끄고 2~3분 동안 iOpener를 물에 담가 두세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Handling it by the tag, place the heated iOpener across the bottom casing.
Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
Remove the following screws holding the rear case to the rest of the phone:
Two 3.15 mm Phillips #00 screws
One 4.15 Torx T5 screw
One 4 mm Torx T5 screw
Place your fingers on either side of the phone and gently push up on the rear case.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
Use the pointed edge of a spudger to work the ZIF cable out of its connector.
Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
