소개
If you are having trouble hearing during a call or cannot hear at all, a faulty ear speaker could be to blame. Follow these steps to replace the ear speaker.
필요한 것
Power off your device.
Remove the bottom cover by sliding it off.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
Pry the vibrator out of the housing with a spudger.
Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
Remove the 3.0 mm Phillips #0 screw.
