소개
If you're having issues with your battery not lasting long or not charging at all then the best solution would be to replace it with a new one.
필요한 것
Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
Using a plastic opening tool, carefully separate the display screen from the rear panel.
Set aside the rear panel.
Remove the five screws at the top of the panel using a Phillips head screwdriver.
Two 2.05mm Philips head screws
Three 2.44mm Philips head screws
Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
Two 3.35mm Philips head screws
Use tweezers to disconnect the antenna from the logic board to the PCB board.
Remove the tape connected to the motherboard.
Remove the tape holding the battery in place.
Gently lift the battery from the bottom using a plastic opening tool.
You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
Now that it's separated, remove and set aside the PCB board.
Place the battery back into its original position once the PCB board has been removed
Use tweezers to disconnect the power button flex cables.
Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
Disconnect the touchscreen flex cable
Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
You may now remove the board safely
Hold the battery perpendicular to the logic board and simply pull it out to remove it.
You can now plug in the new battery.
다른 4명이 해당 안내서를 완성하였습니다.
