주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
HTC One X is also known as S720E.
How to disassemble the phone and change the LCD Display & Touchscreen / Digitizer (the complete spare part).
Please SUBSCRIBE to my channel ツ
동영상 개요
  1. Switch-off the phone (if you can). Remove the SIM tray. The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
    • Switch-off the phone (if you can).
    • Remove the SIM tray.
    • The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
  2. Start opening from the bottom side. For separating the back cover, use only plastic tools. For separating the back cover, use only plastic tools.
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. The mother board is held by 6x Philips screws. The mother board is held by 6x Philips screws. The mother board is held by 6x Philips screws.
    • The mother board is held by 6x Philips screws.
  4. Disconnect one by one: the Touchscreen flex cable the Volume buttons & Mic flex cable
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Use a plastic tool to unstick the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  5. Lift the motherboard slightly to disconnect two flex cables: the LCD Display flex cable the Navigation buttons flex cable
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery from the mainboard.
  6. At the beginning you can use a cutter to make a room for the plastic tool. During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy. During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
    • At the beginning you can use a cutter to make a room for the plastic tool.
    • During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
  7. The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original. Gently assemble the screen to the frame. Gently assemble the screen to the frame.
    • The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
    • Gently assemble the screen to the frame.
  8. Did you do it successfully?
결론
다른 14명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
168,623 평판
안내서 306개 작성하였습니다
Master Techs Master Techs 회원
Community
291 회원들
안내서 831개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 30
전체 시간: 37,149
