주요 콘텐츠로 건너뛰기
HTC One X Plus Battery Replacement
필요한 것
  1. HTC One X Plus Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: 2 단계, 이미지 1/3 HTC One X Plus Battery Replacement: 2 단계, 이미지 2/3 HTC One X Plus Battery Replacement: 2 단계, 이미지 3/3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: 3 단계, 이미지 1/3 HTC One X Plus Battery Replacement: 3 단계, 이미지 2/3 HTC One X Plus Battery Replacement: 3 단계, 이미지 3/3
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: 4 단계, 이미지 1/3 HTC One X Plus Battery Replacement: 4 단계, 이미지 2/3 HTC One X Plus Battery Replacement: 4 단계, 이미지 3/3
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: 5 단계, 이미지 1/2 HTC One X Plus Battery Replacement: 5 단계, 이미지 2/2
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: 6 단계, 이미지 1/3 HTC One X Plus Battery Replacement: 6 단계, 이미지 2/3 HTC One X Plus Battery Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Vitterio Crisp
회원 가입일: 08/26/15
119 평판
안내서 1개 작성함
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 4,057
